Salta al contenuto principale
HP Pavillion 15-cs0053cl 15" Laptop released in 2018.
How to fix battery?
Im having problems with my HP Pavilion's laptop battery. Can someone teach me how to repair it?
Questa è una buona domanda?
Punteggio 0
Aggiungi un commento
1 Risposta
Risposta Più Utile
Hi,
Here's the maintenance and service guide, taken from this support webpage, for the laptop.
Go to p.37 to view the necessary pre-requisite steps and then the procedure to remove/replace the battery.
At the top of the page you will find the HP part numbers for the available batteries. Search online using the part number only to find suppliers that suit you best.
Try creating a battery report to check the status of the battery, before replacing it to see if it is the problem. Check the Design Capacity versus the Full Charge capacity.
Punteggio 1
Aggiungi la tua risposta
Sebastian Pagán Olivera sarà eternamente grato.
Visualizza Statistiche:
Ultime 24 Ore: 1
Ultimi 7 Giorni: 6
Ultimi 30 Giorni: 27
Tutti i Tempi: 730
