Why did #3 cylinder spark plug striped when trying to remove it
Why did # 3 cylinder spark plug on my 1999 Explorer stripped when trying to remove it.
Questa è una buona domanda?
It maybe the plug was cross threaded when installed. It is’nt the end of the world though. You can buy a rethreading kit for spark plugs these days, fairly inexpensive too. I had to do the same job on my motorbike engine. I got a 15mm Helicoil kit that came with a 16mm thread tap. Once id run the tap down the hole of the alloy head, the helicoil then screwed in & you would never know there had been a problem.
Heres a similar kit to the one i used. I know my motorbike is different to your car engine but it is a similar process to repair the stripped thread.
Ultime 24 Ore: 0
Ultimi 7 Giorni: 0
Ultimi 30 Giorni: 5
Tutti i Tempi: 76
Aluminum cylinder heads? Black bodied or nickel plated spark plugs?
da F Dryer
