Salta al contenuto principale
Released in June 2016, the Altec Lancing BoomJacket 2 is a small, portable bluetooth speaker. It is designed to work anywhere without the worry of it getting damaged by the elements. Model Number IMW579-AB-BB ( aqua blue)
6 Domande Visualizza tutte
Why does my speaker stop responding
I have the Altec Bluetooth IME579-AB speaker. Why does it stop responding when the Bluetooth setting on my phone shows it still has a 50% charge. Other Bluetooth devices are able to connect to the same phone and continue to work fine.
Questa è una buona domanda?
Punteggio 0
Aggiungi un commento
1 Risposta
Try connecting it t charger and useing it. If it works that way and doesn't disconnect then you have a battery indicator that's out of sync.
Punteggio 0
Aggiungi la tua risposta
David Elliott sarà eternamente grato.
Visualizza Statistiche:
Ultime 24 Ore: 0
Ultimi 7 Giorni: 0
Ultimi 30 Giorni: 0
Tutti i Tempi: 63
