Salta al contenuto principale
Repair and troubleshooting information for the HP EliteBook 840 G5, an HP laptop part of the HP EliteBook series. Released in February 2018.
Why does my laptop only work when I charge the battery externally
I have two elite books and I tend to play around with them. So I have to unplug and replug the battery a lot. But a little while ago I noticed that one them when it was charging and it still gave me a low battery warning and then it died. So I took the battery from the non-dead one and put it in the dead one and it turned on but it wouldn’t charge, so I would swap battery’s between them for a little while but then the same thing happened to the other one. And now they’re both dead so how do I fix this?
Questa è una buona domanda?
Punteggio 1
Aggiungi un commento
4 Risposte
Risposta Più Utile
Have you tried calibrating the batteries as below?
https://www.partitionwizard.com/partitio...
https://www.howtogeek.com/172271/how-to-...
https://windowsreport.com/calibrate-lapt...
And run the battery report on both batteries:
https://www.lifewire.com/how-to-generate...
Punteggio 1
maybe the power supply cable is loose, see if you can unplug and plug the power supply back in.
Punteggio 0
The G5 is a few years old at this point. While it’s unheard of for batteries to fail as I have two (i7-8550U/4K and a i7-8650U/SV deleted one) with original batteries, it happens but not as often as say, a G1-3 which are much older. I also have one I got for parts thinking it had a BIOS password and ended up repairing (it didn’t, so I threw a screen assembly on as it was an SV model before I yeeted that option— i5-8250U variant). The first thing I check on a suspect battery is the DOM printed on the battery. If it’s a few years old, I would check the FCC (full charge capacity) on the packs in the HP diagnostics to quickly check. If it isn’t the charger, the battery is the second most likely failure. I’ve seen “no battery” units on the market, which is code for expanded cells and was removed to sell the laptop.
If you hook these up to an Ethernet switch or router with an actual cable (read: not WiFi — doesn’t work), you can run and check under Advanced, look for an option called “Execute Remote HP PC HW Diagnostics”. Once you do that, you go under “Component tests” and select “Power”, and in turn test the battery. If it’s below 80%, it may be time for a new battery. However, I’d try and reset the BIOS as well as recalibrate both packs even if you need to get **enough** charge on it to defeat the BIOS lockout HP is known for on the one that can handle it and then see if both units accept their original batteries.
NOTE: If you can’t use Ethernet, load the diagnostics onto the UEFI partition if it isn’t present. Click here for the utility to copy it to the UEFI partition.
If you see this screen, you don’t have it installed locally:
Here’s how to access the diagnostics remotely:
If that doesn’t work, reset the BIOS to factory defaults — disconnect both the primary and CMOS for 30 seconds, let the notebook settle for a minute while it reloads the backup BIOS and see if the issue remains.
Punteggio 0
Good morning, this issue is very common among the 840 series because the type of charger used is the blue pin type. You may be surprised the batteries are ok. You need a charger with better Amperage. I guess this will work perfectly.
Punteggio 0
Aggiungi la tua risposta
Daniel Murray sarà eternamente grato.
Visualizza Statistiche:
Ultime 24 Ore: 0
Ultimi 7 Giorni: 3
Ultimi 30 Giorni: 26
Tutti i Tempi: 625
