Salta al contenuto principale
A Desktop PC built from off-the-shelf DIY parts, rather than a prebuilt from a major manufacturer. These can also be built by an SI using off-the-shelf parts.
170 Domande Visualizza tutte
Why can’t I get into bios so I can download windows
I can’t get into the bios on my computer. I just finished putting everything together and I can’t get into bios no matter how many times I spam the bios key for my computer after turning it on.
Questa è una buona domanda?
Punteggio 0
1 Commento:
Hi @rothtorb,
What is the make and model number of the motherboard?
da
Aggiungi un commento
2 Risposte
Go to the support page on your motherboard manufacturer’s website, they'll probably have a page that tells you how to enter the BIOS on your motherboard. You should make sure your keyboard is plugged directly into your motherboard and try just plugging your installation media (I'm assuming it's a flashdrive with a Windows ISO flashed onto it) directly into your motherboard.
Punteggio 0
The main Keys to get to BIOS are going to be Esc, F1, F2, F9,F10 and F12 Sometimes Del. You may have to go to a Boot List and Pick Setup to go to BIOS. If you look the Board up it should tell you what Key it is. Another tick you can use at times is to remove all Boot drives and turn it on sometimes it will ask if you want to go to Setup.
Punteggio 0
Aggiungi la tua risposta
Torben Rothgeb sarà eternamente grato.
Visualizza Statistiche:
Ultime 24 Ore: 0
Ultimi 7 Giorni: 1
Ultimi 30 Giorni: 2
Tutti i Tempi: 57
