Salta al contenuto principale
iPhone di quarta generazione. La riparazione è semplice, ma il vetro anteriore e l'LCD andranno sostituiti insieme. GSM / 8, 16, or 32 GB di memoria / Modello A1332 / Nero e Bianco.
20 Domande Visualizza tutte
4s Back Panel Is Stuck On
I have removed both screws, but the back panel will not slide up. I’ve tried increasing pressure, cleaning the sides with alcohol and increasing grip with some gaffer tape. I can’t replace the battery if I can’t open it. What am I doing wrong?
Questa è una buona domanda?
Punteggio 0
Aggiungi un commento
1 Risposta
The battery is probably expanding and putting pressure on the back glass making it harder to slide up. I would try putting the phone face down on a non slip surface like a rubber mat or something then slide the back up while putting slight downward pressure on the phone.
Punteggio 0
2 Commenti:
Hi Jay, I'm jumping in on @xnriqux's answer. If you think the battery could be swollen, make sure to be really cautious working on you device. A swollen battery is quite dangerous–it can be a serious fire hazard. Check out our wiki on swollen batteries before you attempt your repair so you can be extra cautious! What to do with a swollen battery
da
@amber Thank you!
da
Aggiungi la tua risposta
Jay Hackens sarà eternamente grato.
Visualizza Statistiche:
Ultime 24 Ore: 0
Ultimi 7 Giorni: 0
Ultimi 30 Giorni: 0
Tutti i Tempi: 47
