Salta al contenuto principale
The Mac Pro First Generation is an Intel Xeon-based workstation computer manufactured by Apple Inc. The first generation model includes the machines from 2006 through 2008.
Power Light is always on and will not boot
Hello,
the Power Light of my Mac Pro is always on. I can switch on/off the Mac (when I push the Power Button, the 4 LEDs on the RAM Board light up briefly and then only 1 stays lit on-and the Fan also goes on) The same the opposite, when I push the Power Button for a short while, the one LED on the Memory Board goes off and also the Fan. But the power light always stays on no matter what I do. The only way to switch it off is to remove the Power. I have tried resetting the NVRAM, PRAM and SMC- sometimes I am successful ans able to start up, but then the next day no more.
Any suggestions would be greatly appreciated!
Thank you
Dorian
Questa è una buona domanda?
Punteggio 0
1 Commento
I forgot to mention it is a 3.1 Model, I think A1186 (?)
da
Aggiungi un commento
1 Risposta
Risposta Più Utile
I think its the power supply
Part: ???
Guide: Mac Pro First Generation Power Supply Unit Replacement
Punteggio 1
4 Commenti:
I'm doubtful it's a power supply issue. I've tried 3 different working PSUs and they didn't resolve the problem.
da
Forgive me. I forgot to mention. I am running a 3,1 with dosdude 1's Mojave. The machine has now resorted to shutting down within 2 minutes after boot rendering it unusable.
da
Previous shutdown cause is -2. What does that mean?
da
@dwcdv - Did you try looking at the motherboard while its on with the sidepanel off,
look around for some lights near a button,
Press said button and post a picture of the lights
https://www.macspecialist.org/mac-pro-ea...
da
Aggiungi la tua risposta
Dorian Weber sarà eternamente grato.
Visualizza Statistiche:
Ultime 24 Ore: 0
Ultimi 7 Giorni: 0
Ultimi 30 Giorni: 5
Tutti i Tempi: 192
