Salta al contenuto principale
Designed in 1991, the fourth generation Maxima arrived in May 1994 for the 1995 model year as the A32.
8 Domande Visualizza tutte
Why does my car die when put in gear?
It starts great. Stays running but when put in gear & given gas, it's dies & when I push the gas petal it doesn't go anywhere & acts like it's not getting any gas! Please help! ,?
Questa è una buona domanda?
Punteggio 0
Aggiungi un commento
1 Risposta
An automatic car can stall when put into gear for countless reasons. It could be a result of a faulty coolant sensor, bad alternator, empty fuel tank, bad fuel pump, leaking vacuum when the filter is blocked, etc.
Punteggio 0
1 Commento:
If the vehicle idles for several minutes without a problem, and only dies when put into gear, it's probably not a fuel pump or fuel tank issue.
da
Aggiungi la tua risposta
Shonda Hayes sarà eternamente grato.
Visualizza Statistiche:
Ultime 24 Ore: 0
Ultimi 7 Giorni: 0
Ultimi 30 Giorni: 4
Tutti i Tempi: 134
