Salta al contenuto principale
How to convert replacement battery pack, 4-pin jst connector to 3-pin
Immagine
Immagine
Hi there, my mobile router battery recently swelled and I needed to replace it but could only find a replacement that comes with a 4-pin jst wire connector however my previous battery had a 3-pin jst wire connector. Am I able to convert the 4-pin into 3-pin so that it will be able to slot in, on the mobile router circuit board
Questa è una buona domanda?
Punteggio 2
2 Commenti
Hi,
What is the make and model number of the mobile router?
What is the full model number on the battery that was in the router? (printed on battery)
Converting 4 wires to 3 might not be safe to do if you don't know what the functions of the battery wires are, more so the yellow and the white, assuming that the red and black are the +ve and -ve leads.
You could end up with a fire or overcharging the battery and damaging it, if you connect it incorrectly
da
@jayeff hi thanks for your help. The mobile router is a ZTE MF910. The battery model number is Li3823T43P3h715345
da
Aggiungi un commento
4 Risposte
Risposta più utile
Hi @theshen
Search for Li3823T43P3h715345 (supplier examples only) to get results for suppliers that suit you best
Punteggio 1
Um einen 4-Pin JST-Batteriepack auf einen 3-Pin-Stecker umzuwandeln, müssen zuerst die Leitungen identifiziert werden:
  • Rot = V⁺ (Plus)
  • Schwarz = GND (Minus/Masse)
  • Weiß/Gelb = Sensor oder Balancierung
  • Die zusätzliche Leitung wird je nach Gerät eventuell nicht benötigt.
Nur die drei erforderlichen Leitungen (meist Plus, Minus und Sensor) in ein 3-Pin-Gehäuse einsetzen und die Belegung vorher mit einem Multimeter prüfen, um Schäden zu vermeiden.
Mehr Details findest du in diesem Leitfaden auf Kasuo
Punteggio 0
  • Rot = V⁺ (Plus)
Punteggio 0
To convert a 4-pin JST battery pack to a 3-pin connector, first identify the wires:
  • Red = V⁺ (positive)
  • Black = GND (negative)
  • White/Yellow = sensor or balance lead
  • Extra wire may be unused depending on the device.
Re-terminate only the required three wires into a 3-pin housing (usually V⁺, GND, and sensor if needed). Always confirm pinouts with a multimeter to avoid damage.
For more details on how 3-pin connectors work, see this guide on Kasuo
Punteggio 0
Aggiungi la tua risposta
Theshen Moodley sarà eternamente grato.
Visualizza statistiche:
Ultime 24 ore: 1
Ultimi 7 giorni: 11
Ultimi 30 giorni: 53
Tutti i Tempi: 1,770
