How can I fix t612 loose 30 pin dock. Unit works thru aux port
Repair shops won’t do it claim micro soldering involved
Questa è una buona domanda?
Micro soldering is required for most connector repair, there could be someone local to you that does this type of work
you COULD try hot gluing the connector - fix it in place with gaffer tape, and one dash of gun glue at a level plane with the bottom of the connector bowl.
If you are hearing crackling noises also, when connecting your 30 pin i-device, it could be the connector, but could also be interference. Google it, then.
Hot gluing wouldn’t repair the solder joints.
I was apparently asleep during reading. My apologies.
microsoldering of 30-pin
Ultime 24 Ore: 0
Ultimi 7 Giorni: 0
Ultimi 30 Giorni: 4
Tutti i Tempi: 51
