Salta al contenuto principale
Guides and repair information for Altec Lansing speakers.
41 Domande Visualizza tutte
How can I fix t612 loose 30 pin dock. Unit works thru aux port
Repair shops won’t do it claim micro soldering involved
Questa è una buona domanda?
Punteggio 0
Aggiungi un commento
2 Risposte
Soluzione Prescelta
Micro soldering is required for most connector repair, there could be someone local to you that does this type of work
Punteggio 1
you COULD try hot gluing the connector - fix it in place with gaffer tape, and one dash of gun glue at a level plane with the bottom of the connector bowl.
If you are hearing crackling noises also, when connecting your 30 pin i-device, it could be the connector, but could also be interference. Google it, then.
Punteggio 0
2 Commenti:
Hot gluing wouldn’t repair the solder joints.
da
I was apparently asleep during reading. My apologies.
microsoldering of 30-pin
https://www.youtube.com/watch?v=ulsK0U9q...
da
Aggiungi la tua risposta
olemonty sarà eternamente grato.
Visualizza Statistiche:
Ultime 24 Ore: 0
Ultimi 7 Giorni: 0
Ultimi 30 Giorni: 2
Tutti i Tempi: 70
