Salta al contenuto principale
Repair guides and information for kitchen food scales.
Why does my scale not read reliably or return to zero reliably?
Duronic kitchen scales KS865 - wheatstone bridge strain gauge-based balance.
The scales tare correctly, but when I place an object of known weight on it reads low. When I take that object off it does not quite return to zero. The scales have recently been dropped.
Questa è una buona domanda?
Punteggio 0
Aggiungi un commento
1 Risposta
Soluzione Prescelta
I found that the load plate (top part) of the scales had become slightly twisted in its mounting (through the strain gauge) to the base of the scales. This was causing the load plate to rub slightly on the base and make the readings unpredictable. By slackening the two screws that mount the load plate to the strain gauge, and realigning, I was able to get the scales working perfectly again.
Punteggio 0
Aggiungi la tua risposta
dan_6384856255 sarà eternamente grato.
Visualizza Statistiche:
Ultime 24 Ore: 0
Ultimi 7 Giorni: 1
Ultimi 30 Giorni: 6
Tutti i Tempi: 219
