Salta al contenuto principale
A new version of the Galaxy Tab A 10.1 was announced in February 2019, with Android 9.0 Pie (upgradable to Android 10 and 11), the Exynos 7904 chipset and an IPS display with an unchanged resolution. The rear flash is removed, S-Pen support is dropped and the battery is smaller, while the front camera is upgraded to 5 MP and the speakers are now stereo. Models numbers: SM-T515 & SM-T510.
Replacing fpc connector t510 tablet
Hi I need to replace the fpc connector in picture wondering if anyone knows the name of connector. Also I have a 858d soldering station and wondering best heat and air flow to replace this part on screenshot. Thanks
Update (12/06/2021)
screenshot
Questa è una buona domanda?
Punteggio 1
1 Commento
Been informed that the part is not compatible with t510
da
Aggiungi un commento
2 Risposte
Soluzione Prescelta
@spiderjocky12 that is reference designator HEA7000 and the Samsung part number for that is 3711-009408. Available at places like this and here as well I am certain there are many more p[laces out there. Good luck with this task.
Punteggio 0
1 Commento:
Thanks appreciate it definitely sorted that
da
My charging port pins are destroyed, can I use an android type c charge port and solder it onto the charging board?
Punteggio 0
Aggiungi la tua risposta
Spider sarà eternamente grato.
Visualizza Statistiche:
Ultime 24 Ore: 0
Ultimi 7 Giorni: 2
Ultimi 30 Giorni: 18
Tutti i Tempi: 324
