Salta al contenuto principale
A new version of the Galaxy Tab A 10.1 was announced in February 2019, with Android 9.0 Pie (upgradable to Android 10), the Exynos 7904 chipset and an IPS display with an unchanged resolution. The rear flash is removed, S-Pen support is dropped and the battery is smaller, while the front camera is upgraded to 5 MP and the speakers are now stereo. Models numbers: SM-T515 & SM-T510.
32 Domande Visualizza tutte
Replacing fpc connector t510 tablet
Hi I need to replace the fpc connector in picture wondering if anyone knows the name of connector. Also I have a 858d soldering station and wondering best heat and air flow to replace this part on screenshot. Thanks
Update (12/06/2021)
screenshot
Questa è una buona domanda?
Punteggio 1
1 Commento
Been informed that the part is not compatible with t510
da
Aggiungi un commento
2 Risposte
Soluzione Prescelta
@spiderjocky12 that is reference designator HEA7000 and the Samsung part number for that is 3711-009408. Available at places like this and here as well I am certain there are many more p[laces out there. Good luck with this task.
Punteggio 0
1 Commento:
Thanks appreciate it definitely sorted that
da
My charging port pins are destroyed, can I use an android type c charge port and solder it onto the charging board?
Punteggio 0
Aggiungi la tua risposta
Spider sarà eternamente grato.
Visualizza Statistiche:
Ultime 24 Ore: 0
Ultimi 7 Giorni: 0
Ultimi 30 Giorni: 5
Tutti i Tempi: 181
