Salta al contenuto principale
Tablet a marchio Google con schermo da 7". Il dispositivo richiede solo strumenti di apertura e cacciaviti per la riparazione. Numero modello: ME370T.
Tablet won't turn on
Whenever I try to turn on the device it just blinks the notification light 3 times. I’ve tried charging it but no luck. Can someone help?
Update (12/03/2021)
Figured it out. For one it was 5 blinks, not 3, and also you just need to charge it longer it seems. I recommend
90 minutes - 2 hours.
Questa è una buona domanda?
Punteggio 0
Aggiungi un commento
1 Risposta
I would recommend you try a different cable and/or wall wort charger that is a 2a rated one. but it is most likely a cable issue. some use 2 paths of power to charge and if one path is damaged you get slow/no charging.
Punteggio 0
Aggiungi la tua risposta
Jack Swallowell sarà eternamente grato.
Visualizza statistiche:
Ultime 24 ore: 1
Ultimi 7 giorni: 2
Ultimi 30 giorni: 22
Tutti i Tempi: 311
