Salta al contenuto principale
The Motorola X Sol Republic Deck is a bluetooth speaker designed by Motorola, released in August 2013.
12 Domande Visualizza tutte
My deck got wet. Is it salvageable?
So, my toddler sprayed my motorola x sol republic deck with the hose. I turned it off immediately and let it dry for about 2 months before turning it on.
Since then, it will connect, but it seems like there’s a short circuit now. If I adjust the volume using the deck’s buttons, it will power down. And the sound cuts out so frequently you can’t listen to anything. Is it salvageable?
Questa è una buona domanda?
Punteggio 1
Aggiungi un commento
1 Risposta
Risposta Più Utile
@nosh27 this “let it dry for about 2 months “ possibly corroded some of the components on the circuit boards. Use these guides Sol Republic Deck and try to take it apart as much as you can. Clean the boards with a soft brush and some high-grade isopropyl alcohol. Check for burned-out or damaged components. Post some pictures of your boards etc. so we can see what you are looking at. After it is all cleaned of any corrosion, replace the battery as well and see what you get. Aggiungere immagini ad una domanda
Punteggio 1
Aggiungi la tua risposta
nosh27 sarà eternamente grato.
Visualizza Statistiche:
Ultime 24 Ore: 1
Ultimi 7 Giorni: 3
Ultimi 30 Giorni: 4
Tutti i Tempi: 51
