Salta al contenuto principale
Rilasciato il 16 settembre 2016. Modello 1660, 1778. Disponibile come GSM o CDMA / 32, 128 o 256 GB / Rose gold, gold, silver, black e jet black.
2265 Domande Visualizza tutte
iPhone stuck at 0.015 A
iPhone 7 Came in with NO BOOT, there was previous work done and the previous tech had changed the NAND. Popped it under a thermal cam and a resistor on the line NAND_ZQ was short. Removed it and no more short. Now the phone is getting stuck at 0.015 A upon prompt to boot. Not going any further.
Any help would be appreciated!
Questa è una buona domanda?
Punteggio 0
Aggiungi un commento
1 Risposta
Soluzione Prescelta
A resistor on this line cannot get shorted Myron. Remember a resistor is like a wire and will reduce current so if one end is connected to ground you will get very low resistance on your multimeter causing it to beep. This resistor probably needs to be there.
Punteggio 1
Aggiungi la tua risposta
Myron. sarà eternamente grato.
Visualizza Statistiche:
Ultime 24 Ore: 1
Ultimi 7 Giorni: 4
Ultimi 30 Giorni: 4
Tutti i Tempi: 58
