Salta al contenuto principale
Mid 2006 / Model Number: A1181 / black or white case / 1.83 or 2.0 GHz Intel Core Duo processor
418 Domande Visualizza tutte
How to connect a magsafe to a solar panel
Hi!
I recently bought a solar panel(Solar Gorilla), but to use it with my MacBook I need to fork out a large sum for the adapters. I have an old magsafe adapter, and several connector tips. Can I somehow connect the magsafe plug to a tip and get power without spending money?
Any help would be welcome!
Hazel
Questa è una buona domanda?
Punteggio 13
10 Commenti
Great Question Hazel, can't wait to hear some ideas from the patrons here. Vote-up.
da
Does the Solar Panel Output 12V AC?
da
What country are you in and what is the electrical standard?
da
I think solar panels typically give DC, especially if it's 12V.
da
I fixed it. This is what I did! It's so simple I had to laugh.
I canabalised the Solargorilla's 20v power socket cable, cut the cord, and joined it to the magsafe connecter cord – and it worked. It runs my MacBook, but does not charge it. Maybe someone can explain to me why. It the current not strong enough?
I'm not very knowlegable about electronics, but interested to learn more.
I'm pleased as punch with my simple solution,even though it is not elegant and I may find I need to reconnect the original cord at some point.
Thanks for your encouragement.
Hazel
da
Mostra altri 5 commenti
Aggiungi un commento
9 Risposte
Soluzione Prescelta
Here's where I think your problem lies...
Mac computers draw a fair bit of current. If you look at your magsafe puck it's likely 60 or 85W (i think) and 35ish for the macbook air. In order to get 60W from a solar panel, you're looking at something the size of your computer desk (2ftx3ft minimum). The Gorilla charger looks to put out about 10W. So, will your computer register that it's "charging", probably. But this is likely not the case. It only registers that because your magsafe is plugged in and there is SOME current coming from it, but not enough to actually run your computer. I don't know what the actual draw is on a macbook but it's more than 10W (Volts X Amps). So, when you're running off of your solar panel you're actually drawing most of your power from your battery and only a tiny bit from the panel. The net result of this is that you actually kill your battery. Not sure why, it just does. Same goes if you try to charge a macbook pro with a macbook/macbook air charger. The current isn't sufficient, and because of that it draws strangely on your battery and WILL kill it. My friend has gone through 3 macbook pro batteries because he was using a 60W charger rather than a 85W. Took him 3 batteries to figure out why they were dying after only a week.
If you do want to charge your macbook with a solar panel, I'd only do it if your computer is off. I think this should work to slowly recharge your battery.
My theory behind this method. Lithium batteries die when they drop below a certain voltage. Your computer knows this and shuts down before you get into this critical phase of the battery cycle. When you use your solar panel your computer "thinks" it's charging properly and therefore doesn't shut down when the battery gets critically low (because a normal mac charger has enough current to power your computer and charge your battery at the same time). Your makeshift charger cant perform both of these tasks because it doesn't pump enough juice. As a result, you constantly drain your battery (albeit slowly because the solra charger is aiding a little) below it's safe range. Inevitably, your battery drops below the critical voltage (something like 2.8v per lithium cell) and it will never charge again.
Does using a solar charger always kill your computer battery, no, but more than likely it's going to dramatically shorten the life of it.
Cheers
W
Punteggio 7
1 Commento:
This one is tough. I looked up the Solar Gorilla and they make you buy a $60 adapter. There is a solar power "generator" from Voltaic Systems that costs $500, so that is spending more money if you return the Gorilla.
If you can try to make a jumper from 10 or 12 wire and alligator clips and make connections on pins until you have the power you need. It may be as simple as clipping to the regular 2 prong wall plug.
If you have a multimeter this may be the way the way to test the output of the solar panel prior to hooking up to the actual computer.
That being said, I hope you can do it so you don't have to spend another dime!
Regards,
Frank
Punteggio 4
Solar panels put out DC electricity
Look at what your AC/DC power charger for you computer put out for DC.
V is voltage
A ( or I) is current in amperes
W is watts (power)
W=VA
For example a MacBook. A 16.5 V 3.65 A is required to charge the battery. To find the power (W) 16.5 X 3.65 = 60.225, this the power required and is also the power of the solar panel you will need a 12V 60W rated solar panel
You can also make a solar generator, a solar panel+ charge controller + a deep cycle battery and a power inverter.
Punteggio 2
I live off-grid. I have a MacBook Pro 17" (model A1261) which requires a 85W power supply. I also have a Solar Gorilla and a Power Gorilla which I used for a summer before I got the main solar system up and working.
You can't run the laptop directly off the Solar Gorilla because the power supply is too variable. There's a massive difference in what a panel can output in full sun and what happens when clouds pass over. The idea is to charge a battery (ie. the Power Gorilla) with the panel and then use the battery to run/charge your devices. The best use of the combo I found was to remove the laptop's battery and run the computer directly off the Power Gorilla. It doesn't draw a constant 85W and the bulk of the draw is for battery charging, so avoid processor-intensive operations and you can get a reasonable amount of time out of it. And I did shell out for the 3rd party MagSafe connector Solar Gorilla supply.
Punteggio 2
For a more "elegant" but a bit pricy connection, I can suggest the use of a MagSafe Travel adapter to connect the Mac to the power output, together with a "lighter" connection since the travel adapter can fit into something of the kind. Of course this will run the Mac but not charge it..
Punteggio 1
Apple loves to sell power supplies. Accordingly, the magsafe plug is designed to fail (short-circuit) with a half twist of the "cable to L plug" joint.
In order to invalidate any effort at self repair, there is a small controler in the magsafe plug that communicates with the "recharge circuit" inside the computer, and it is bloodily hard, if not impossible, to repair it without breaking some of the fragile circuits inside (notably the unprotected leds).
Now, if the computer detects that you have fiddled with anything, it will take the voltage to power the computer, but will refuse to charge the battery, effectively leaving you with no option but to plunk 79$ on the counter for another soon-to-die apple power adapter.
How grand is that...
Punteggio 0
1 Commento:
There is no controller inside the Apple-chargers, but simply a resistor in the connector, which value "tells" the mac the type of charger (about this mac).
A Macbook (white) gratefully took 15...20V DC from whatever source and worked.
So no real evil there :-)
da
http://mikegyver.com/Magsafe-car-adapter...
i run a solar panel to a battery with a dc charge controller. That way the battery smooths out the DC power for the macbook.
brunton charge controller
solaris 26 watt foldable.
Do yourself a favor and look into ares / powerpoles so you never have to worry about which direction to wire everything.
Punteggio 0
You should be able to do a slow charge whilst your MB is turned off. That won't happen while it's on. You should be able to get a longer operating period though with the panels connected.
Punteggio 0
Apple MagSafe Airline Adapter which is capable of attaching to your MBP via MagSafe - but then it's got the DC power connector on the other end. THEN you could connect your MBP to the folding solar power panels.
In theory, this could work. I'm not sure since I've never tried it - apparently there isn't anyone on this site who has. There are also other issues surrounding this topic. The solar power panels only provide upwards of 26watts of power - which we all know is insufficient since the MBP needs 85watts of power.
Do a search to find one that provides the power output that you need and see if fits your needs. I do know from the very fast search I conducted that these products are expensive! Maybe you could buy a couple of extra batteries to take on the trip with you. Might come out cheaper that way.
*Disclaimer* In know way am I attempting to be an expert on this subject. Just merely offering my two cents.
Hope this helps.
Punteggio 0
Aggiungi la tua risposta
Hazel sarà eternamente grato.
Visualizza Statistiche:
Ultime 24 Ore: 11
Ultimi 7 Giorni: 25
Ultimi 30 Giorni: 34
Tutti i Tempi: 19,954
