Salta al contenuto principale
Rilasciata nel novembre 2020, la consolle PS5 si caratterizza per la capacità grafica notevolmente migliorata e un innovativo controller DualSense. Lo schema cromatico futuristico in bianco e nero segna una grande svolta rispetto al design delle PlayStation del passato.
191 Domande Visualizza tutte
Why is my disc drive slow sometimes
Hello. Could someone can help me out? I had my ps5 for about a month and noticed that my bluray drive is slowing. It wasnt much slower until recently where disc sometimes gets stuck halfway in and then louder sound comes from drive and it almost feels like it force inserts it in. I found a fix but it didn't last long maybe day or 2. I blowed really hard and the drive went back to normal speed but it isnt permament. Q tip and alcohol like on ps4 drive didnt hold aswell. Something is definitively wrong with rollers perhaps they get dirty fast or idk. Anyone had same issue or similar one and is there a way of fixing it easy pls let me know? I'm under warranty so I don't want open it up but I dont want to send it to service either. So if there is a easy fix pls lemme know. Its a really frustrating thing…
Questa è una buona domanda?
Punteggio 0
Aggiungi un commento
1 Risposta
Soluzione Prescelta
How long is the warranty,
also if i was you i would try replacing the drive,
The motor might be faulty inside the drive
Respond when possible.
Punteggio 2
4 Commenti:
I'd even say gears are fine its probably the rollers that get dirty fast from somewhere as only solution is to blow using q tip and alc. Disc is being read either way when it goes slow or normal.
da
Yeah gears are definitively fine and disc is read either way. I managed to solve problem by using kitchen knife to scratch dirt of rollers that got stuck on them and used q tip to clean any remaining dirt however im keepimg my ps5 horizontal as it work rly smooth that way if i put it vertical slow disc read might happen but it really rare currently mostly when i get a new game then it happens once or twice thats it. Horizontal never so thats the way il keep it
da
Alright exept my answer please
da
Hello,
i have the same problem. Disk drive delays to accept the disc. Did you find any solution?
da
Aggiungi la tua risposta
Filip Trusk sarà eternamente grato.
Visualizza Statistiche:
Ultime 24 Ore: 2
Ultimi 7 Giorni: 14
Ultimi 30 Giorni: 74
Tutti i Tempi: 2,795
