Salta al contenuto principale
Rilasciato il 16 settembre 2016. Modello 1660, 1778. Disponibile come GSM o CDMA / 32, 128 o 256 GB / Rose gold, gold, silver, black e jet black.
2264 Domande Visualizza tutte
iPhone 7 Shutting down when placing or ending a call
Hey,
Very weird problem I have encountered here. Checked Panic Logs and it says something regarding to i2c3. Attached the Panic Logs here: http://hastebin.com/legiwixexa.json
Any help would be really appreciated! :D
Questa è una buona domanda?
Punteggio 0
Aggiungi un commento
1 Risposta
Hi,
Before going to deep in the phone, I would reccomend looking at same basics first.
Rule out software by backing up the device and restoring it. Test the calls without anything installed on the phone first.
Rule out the battery. Most iPhone 7 batteries need a replacement by now. A bad battery can often cause random, or odd shut downs or restarts.
You can test those in what ever order that is more convinient for you.
Let me know if that helps, if not i’d be happy to help continuing troubleshooting further
Punteggio 0
Aggiungi la tua risposta
Myron. sarà eternamente grato.
Visualizza Statistiche:
Ultime 24 Ore: 1
Ultimi 7 Giorni: 1
Ultimi 30 Giorni: 2
Tutti i Tempi: 42
