Hi,
Here’s the tech sheet for the refrigerator.
It shows how to get into the diagnostic mode and to initiate the ice dispense function (test #18)
It also shows the wiring path for the ice dispense motor from the ice maker through to the pcb shown as the Minotaur board in the wiring diagram.
Since you have replaced the control board and the motor check that the wiring between the board and the motor is OK. The motor’s two operate wires pass through 5 harness connectors to get to the pcb so the problem may be in finding where each connector is located and then checking the wires for continuity through the connector etc. The ice door motor wiring doesn’t pass through all the same harness connectors as the dispense motor.
I can’t zoom in far enough to make it clear enough to read but the diagram does have the wire colours for every wire which should help. My eyes aren’t what they once were, hopefully yours are better ;-)
The dispense motor connects to the two left most wires on the P3 connector on the pcb, but I can’t make out the terminal pin number so be aware that it may be only shown this way for drawing purposes.
See image below for wiring.
(click on image to enlarge)
Hopefully this is of some help.
Votato
Annulla
Punteggio
2
Annulla
Scorri questo thread per trovare il posto appropriato per questo commento. Quindi, fai clic su "Allega commento a questo post" per spostarlo.
