Salta al contenuto principale
A gaming laptop released by Asus with a CD/DVD drive.
20 Domande Visualizza tutte
Black screen after cleaning and reassemblingm - RESOLVED
A friend of mine gave me a gl552vw that she wasn't using after my lenovo died. I disassembled it to clean it properly and to remove all the little inhabitants and apply new thermal paste. After reassembling it, all I get is a black screen. I was careful not to damage anything but the lid sensor broke off the board anyway. Do you guys think I might have damaged the lcd cable during reassembly or could the little inhabitants have done something inside it
edit: new issue discovered that i thought was normal. it turns on as soon as i plug in the charger
Questa è una buona domanda?
Punteggio 0
Aggiungi un commento
1 Risposta
Risposta Più Utile
Hi @techlord
Did you disconnect the battery from the motherboard when cleaning, you never said?
Connect an external monitor and check if there is a display on it when the laptop is turned on and booted up. If the external monitor works OK, then use a torch and shine it an an angle close to the laptop screen and check for any images. If you see them, (they will be very faint) then there is a backlight problem.
Normally the backlight power is on all the time when a laptop is turned on and it is turned on and off in the LCD panel by a signal voltage from the BIOS (and can also be from the OS to the BIOS) depending on requirements. You said that the lid sensor broke off the motherboard. It is the lid sensor that tells the BIOS whether the lid is open or not so perhaps it thinks that it is now shut so therefore the display is turned off.
Punteggio 1
18 Commenti:
Everything was disconnected and I don't have a monitor so I used my tv and got no picture at all. I plugged in a hard drive and the there was no activity indicating it was trying to boot. I know it was working when it was given to me so I'm stumped as to what I could've done
da
@techlord
Any lights on the keyboard when a charger is connected and the laptop turned on?
is the lid sensor part of the power button board in your model?
Only asking because in some other laptops it is and the power button and sensor use the same cable to the motherboard.
da
i fixed it, i cleaned the ram slots and display cable slots with alcohol and a toothbrush and it removed whatever remains were there from the freeloaders inhabiting it
da
@jayeff it now works but turns on as soon as i plug in the charger and it's not supposed to do that
da
@techlord
The laptop never had a missing lid sensor before.
Don't know but try disabling "Wake up on lid opening" in BIOS and check if that does anything.
Go to BIOS > Advanced > Wake up on lid opening (see p.75 of the user manual)
The default setting is Enabled but it would rely on the lid switch to know if the lid was open or shut.
da
Mostra altri 13 commenti
Aggiungi la tua risposta
Cheap gamer sarà eternamente grato.
Visualizza Statistiche:
Ultime 24 Ore: 1
Ultimi 7 Giorni: 6
Ultimi 30 Giorni: 25
Tutti i Tempi: 1,863
