Salta al contenuto principale
Lanciato il 20 settembre, l'iPhone standard di Apple del 2019 ha LCD touchscreen da 6,1" e doppie fotocamere ed è disponibile in sei colori. È il successore dell'iPhone XR.
LCD?/Screen is Unresponsive To Touch
Dropped my IPhone 11 on hard ground, only one crack went to screen. However after 2 days, the screen became partially unresponsive (the bottom bit didn’t respond to touch). Now 4 days later, screen is totally unresponsive to touch ; Siri works with Hey Siri, phone unlocks with Face ID, side buttons works, camera works, but the screen. responds to no physical touch. What should I do?
Questa è una buona domanda?
Punteggio 2
Aggiungi un commento
1 Risposta
sounds like your device needs a screen replacement, you can either take your device to a mobile phone repair shop to get it replaced for a fee, or you can use this guide to learn how to replace the screen yourself, if you are not comfortable opening your device then I recommend having a repair shop replace it for you, you can read the guide on replacing your phone screen here: Sostituzione pannello schermo iPhone 11
Punteggio 0
Aggiungi la tua risposta
Jup K sarà eternamente grato.
Visualizza Statistiche:
Ultime 24 Ore: 1
Ultimi 7 Giorni: 6
Ultimi 30 Giorni: 41
Tutti i Tempi: 552
