HP pavilion, power light shut down after 5 secunds No display
Did everything, change RAM, check eweryhing !, The problem WAS THE SMALL PIN INSIDE POWER PLUG !
Questa è una buona domanda?
Hi @peterfrida ,
Are you asking how to fix the power connector in your laptop?
They cannot be repaired, they have to be replaced.
Here’s the maintenance and service guide for the laptop, taken from this webpage.
Go to p.64 to view the necessary pre-requisite steps and then the procedure to replace the power connector (supplier example only to show part and cost).
There are other suppliers online that may suit you better. Just search for 641137-001 to get results
Ultime 24 Ore: 0
Ultimi 7 Giorni: 0
Ultimi 30 Giorni: 16
Tutti i Tempi: 146
2 Commenti
Thanks, I Allredy open the male power plug of the power supply with razor blade and modified the small pin inside with needle, I know the outside jacket it's - the inside jacket it's + 19 volts, I don't understand whay HP putting the small pin inside that only recognize HP power supply ?! It's for Spite that you have to purchase original from HP for $80 ! This stupid think Make you trablshut all different problems that are similar to RAM, Display, mother board ,battery ETC..., So thanks HP ! They spend so much engineering for confusing people! The Dell and others don't have that, It comes on but it tells you you need to plug in original power supply !
da Peter Firda
@peterfrida
They're in the business of selling computers etc not making them easy to fix. Look at Microsoft or Apple, they're the same
The only way they will react is if people stop buying their products.
Nothing impacts on them more than the bottom line falling due to slowing sales
da jayeff
