Salta al contenuto principale
Processore dual core Intel Core i5 da 2,3 o 2,6 GHz o quad core Intel Core i7 da 2,7 GHz (fino a 3,7 GHz con Turbo Boost) con 6 MB di cache L3.
How to remove stuck (stripped/damaged patch/thread) screws?
Hi,
I was trying to replace the speakers of Macbook Pro A1398 following this guide Sostituzione degli altoparlanti del MacBook Pro 15" Retina Display versione metà 2012 and I’m stuck at step 31.
I’m unable to remove one 2.6 mm T5 Torx screw (red) and one 5.8 mm T5 Torx screws (left orange one) due to their screw patch (thread) is damaged.
Is there any possible way to remove them using any tool? Any help would be highly appreciated. Thank you.
Best regards,
Arif
Questa è una buona domanda?
Punteggio 0
Aggiungi un commento
1 Risposta
Soluzione Prescelta
You should be able to replace the right speaker as the screws holding it are exposed.
Are you using the proper sized screw driver, is yours worn? I would get a fresh tip/driver to see if that solves the problem. You also need to press down a bit Make sure you open the display so it is hanging over the edge of your work table and have something to pad the keyboard (thin towel or sheet of real chamois leather)
See if a scrap of chamois leather can help in getting a good bite with your driver. I also find a small drop of solvent around the screw head can sometime help and in other cases a soldering iron heating the screw can also help.
Punteggio 0
3 Commenti:
Hi Dan,
Thank you for the tips. I used a new T5 but there’s no grip. May I know where can I find a soldering iron to heat the screw?
Regards,
Arif
da
@arifk - Something like this should do it Soldering Iron 60w Hakko 503F
da
@danj, thank you very much. Appreciate it. Let me try out the methods you mentioned.
da
Aggiungi la tua risposta
Arif Khan sarà eternamente grato.
Visualizza Statistiche:
Ultime 24 Ore: 1
Ultimi 7 Giorni: 2
Ultimi 30 Giorni: 6
Tutti i Tempi: 281
