My Bosch washer sounds bad
My Bosch washer was always quiet ( 10 years old)now it sounds like a nail or coin is stuck in the drum. Everything still works… should I be worried?
Questa è una buona domanda?
Punteggio
0
Ultime 24 Ore: 2
Ultimi 7 Giorni: 5
Ultimi 30 Giorni: 14
Tutti i Tempi: 42
@smbengie what exact model is your Bosch washer?
@jayeff bad tub bearing? Foreign object in the tub? What do you think?
da oldturkey03
@oldturkey03
Rythmical scraping sound might indicate a bearing.
Don't know about getting an object stuck to make a consistent noise pattern. To me they're more likely to rattle because they're shifting about although they could be jammed I suppose
If the tub can be spun manually and it is still heard it may make it easier to locate without the noise of the motor interfering
da jayeff
