Salta al contenuto principale
Informazioni sulla riparazione e guide per l'iPhone 8, lanciato il 22 settembre 2017. Modelli A1863, A1905.
873 Domande Visualizza tutte
Super glue for iPhone 8 back glass
The back glass is lifting off my iPhone 8 at the bottom, and I don’t want/need to replace it. Will it cause any issues if I use super glue around the edge? I don’t care about water resistance. If super glue is a bad idea, are there any other viable options?
Questa è una buona domanda?
Punteggio 0
Aggiungi un commento
1 Risposta
Yeah super glue should be fine as long as it’s only coming up in one section. You won’t have to worry about getting the alignment wrong and then it’s super-glued down…
If the glass does break at any point and you want to replace it, you will have a hard time removing the pieces of glass directly glued onto the frame from your super glue.
Punteggio 0
2 Commenti:
Superglue is probably weaker than whatever uberglue apple currently use for their back panels...
da
@hihellhi Oh for sure. I have to use a massive friggin lazer machine to remove the genuine Apple backglass within a reasonable timeframe if its simply cracked and only cosmetically damaged... I miss the days of simply popping off the plastic back panel on your phone and taking out the battery to get to the sim card !! Priorities have changed.
da
Aggiungi la tua risposta
Caleb H sarà eternamente grato.
Visualizza Statistiche:
Ultime 24 Ore: 2
Ultimi 7 Giorni: 4
Ultimi 30 Giorni: 17
Tutti i Tempi: 1,003
