Salta al contenuto principale
Model A1297 Unibody: Early 2009, Mid 2009, Mid 2010, Early 2011 & Late 2011
544 Domande Visualizza tutte
When booting up screen goes black and continues normally
Hello.
I got a MacBook Pro 17 inch of eBay. When booting up this MacBook Pro, it goes 3/4 of the progress bar, the screen than turns black and than shows the regular login screen.
Is there a problem with the GPU logic or this normal as the graphics are changing between dedicated and integrated? Both GPU’s have no problems as I checked by watching videos and doing browsing.
Update (07/17/2021)
Here is a video of my MacBook Pro booting up
Questa è una buona domanda?
Punteggio 0
2 Commenti
What is the OS-X version you are running on the system. Your system may need a firmware update.
da
It is running high sierra 10.13.6. It also is missing the apple hardware test. It gives me error -3403D
da
Aggiungi un commento
1 Risposta
Soluzione Prescelta
The older Core2Duo Mac’s will do this, nothing you can do to change the short wink out.
As far as the onboard diags I feared that would be the case Apple did you a favor (NOT) when they updated the firmware with High Sierra they killed the onboard diagnostics services! One step forward, two steps back!
I would give the internals a good clean of the dust build up and monitor the thermals using a good monitoring app like TG Pro
Punteggio 2
5 Commenti:
It is actually the mid 2010 17 inch with 2.53 ghz i5 processer @danj
da
One more question. I use Mac Fan Control to cool my thermals down. I cannot see the temperature for the Nvidia GPU or the Intel GPU. Is there a software issue?
da
@Krishay P - Give TG Pro a try it will show the GPU sensors.
da
@danj I have another question. On Mac Fan Control it says my Platform Controller Hub Die is 59-61 Celsius. What is the Platform Hub Controller Die and is the temperature concerning?
da
@Krishay P - Most people just call it the PCH chip. This is the traffic cop of your system sending the data in and out of the CPU and other input/output devices.
I really don't like Mac Fan Control as it doesn't let you see things in a good visual frame work which is why I prefer TG Pro. If that was the only high temp then that would be a concern. But I doubt that is the case!
You likely have other sensors also running high. But without seeing the full picture it is a pointless data point.
da
Aggiungi la tua risposta
Krishay P sarà eternamente grato.
Visualizza Statistiche:
Ultime 24 Ore: 0
Ultimi 7 Giorni: 1
Ultimi 30 Giorni: 1
Tutti i Tempi: 87
