Salta al contenuto principale
Modello A1502 / processore dual core Intel i7 2,6 GHz (Turbo Boost fino a 3,1 GHz) o 2,8 GHz (Turbo Boost fino a 3,3 GHz) con 4 MB di cache L3 condivisa.
What causes these static and moving horizontal lines on display?
I saw in last month these year som flickering after I open display or I typed. Then show up black line at bottom display. Then more and more, maybe because it was more warm outside.
Last week I have macbook in room, normal temperature, and came back after 30min and lines flickering like shadow on full display was added.
I connect it with HDMI and it is OK, screen mirroring is OK too but that is just software thing I think.
I remove battery, of course then I discovered that apple suppress cpu load, and heating is no longer problem. Fan works OK.
Display connector seems to be properly sealed.
Battery I buy if I know where the problem with the screen is.
Q what this can couse that issue ?
Q where can be problem ?
Q what else should i look at ?
Thx
Questa è una buona domanda?
Punteggio 1
Aggiungi un commento
1 Risposta
Risposta Più Utile
Sadly your displays T-CON board is falling!
What you are seeing is the horizontal scan messing up. Time to replace the replace assembly MacBook Pro 13" Retina (Late 2013-Mid 2014) Display Assembly or 13” MacBook Pro Display Assembly, Apple P/N 661-8153 and here’s the guide Sostituzione gruppo dello schermo MacBook Pro Retina 13" metà 2014
Immagine Replace a display compatible with the model A1502 late 2013 to mid 2014 Retina 13" MacBook Pro laptop. Includes the Retina 2560 x 1600 pixel 13.3" LCD screen, display cover, bezel, FaceTime HD Camera, clutch hinges, Wi-Fi antenna, camera, and display data cables.
Prodotto
$449.99
Punteggio 1
9 Commenti:
Q pls what is that #tcon.board ?
Q can I replace only that #board - or I have to buy #whole.display ?
da
@bgbruno - It's part of the display assembly and not replaceable on its own.
da
@danj thx
display is still for big price for 7yr model
Q is there any way i can check before buying that replacing the display will solve this?
da
@bgbruno - Just plug in a external display via the HDMI or Thunderbolt ports, if you see the same issue on it then its deeper within the GPU.
Frankly, I've seen this too many times its always the display ;-{
da
@danj that I already tested - and it is OK
I believe you - you have probably a lot more experiences :-)
Q cannot be flex cable or another cable - or how it looks like if cable would damaged ?
da
Mostra altri 4 commenti
Aggiungi la tua risposta
BG Bruno sarà eternamente grato.
Visualizza Statistiche:
Ultime 24 Ore: 0
Ultimi 7 Giorni: 0
Ultimi 30 Giorni: 9
Tutti i Tempi: 355
