Salta al contenuto principale
The Mac Pro First Generation is an Intel Xeon-based workstation computer manufactured by Apple Inc. The first generation model includes the machines from 2006 through 2008.
Re-Installing OS and Spinning Wheel Is Frozen
I was given a 2008 Mac Pro today. I put a hard drive in it, made a MacOS USB Drive and tried to install the OS. Upon booting from the USB, I’m greeted with the normal Apple screen. The spinning wheel shows up, spins a few times , stops and doesn’t proceed any further. I have tried zapping NVRAM, re-downloading and remaking Installation USB, tried different USB drives, swapped RAM modules and still the same. I am attempting to install OS Mavericks since I know it supports Early 08 and up.
Questa è una buona domanda?
Punteggio 0
7 Commenti:
What is the drive you put in? Make & Model
da
It is a WD Blue 500GB
da
Is this the drive: WD Blue
da
It's an older WD Blue
da
@goetzsage2 - Can you give me the model number of the drive.
da
Mostra altri 2 commenti
Aggiungi un commento
1 Risposta
Why I had asked is many people forget the older Mac Pro systems SATA ports can only support SATA II (3.0 Gb/s) or SATA I (1.5 Gb/s) drives. The newer fixed speed SATA III (6.0 GB/s) drive are not able run in your system directly. You would need a PCIe SATA board.
Are you able to setup the drive externally on your other Mac system using something like this: Universal Drive Adapter
Immagine Turn your current hard drive into an external drive with this adapter.
Prodotto
$24.99
Punteggio 0
Aggiungi la tua risposta
goetzsage2 sarà eternamente grato.
Visualizza Statistiche:
Ultime 24 Ore: 0
Ultimi 7 Giorni: 1
Ultimi 30 Giorni: 5
Tutti i Tempi: 232
