Salta al contenuto principale
Modello fine 2011, A1278 / processore i5 2,4 GHz o i7 2,8 GHz
591 Domande Visualizza tutte
Laptop dies when unplugged
I replaced the battery in this MBP just over a year ago. It now shuts off immediately when unplugged and Coconut Battery registers no battery at all.
Does this indicate a faulty battery or a logic board problem? The latter seems more likely to me, but I’m asking because a battery for another computer of the same model that I ordered from iFixit around the same time last year also recently turned out to be faulty.
Questa è una buona domanda?
Punteggio 0
2 Commenti
Let’s get a better view of things, install this gem of an app! CoconutBattery take a snapshot of the apps main window and post it here for us to see Aggiungere immagini ad una domanda
da
Thanks Dan. Just added the CoconutBattery shot.
da
Aggiungi un commento
2 Risposte
Soluzione Prescelta
Sadly your battery is bad! The micro-controller within it has failed so the communication to your system is not working as well as the charging of the battery.
Time to replace it! I would contact the seller to see if they offer a warranty. As an example iFixit offers a year.
Punteggio 1
Risposta Più Utile
Try replacing the battery again. If that doesn’t do the trick, that is when you should either replace the logic board or the whole MacBook altogether.
Punteggio 1
1 Commento:
Let's first diagnose the issue before we go that far!
da
Aggiungi la tua risposta
thardee sarà eternamente grato.
Visualizza Statistiche:
Ultime 24 Ore: 2
Ultimi 7 Giorni: 6
Ultimi 30 Giorni: 6
Tutti i Tempi: 38
