Outdoor LED light fixture not working, AC power OK.
Hi all - hoping someone has an idea how to repair these outdoor mounted LED lights - They are permanently mounted for providing light in the front entrance area. For awhile they were intermittent, and now just dead. I have verified good AC power to the lights. Other lights and devices on the circuit work fine. I don’t see anything obviously wrong with them.
Anyone know of typical gotchas on these? Surface mount fuse or rectifier or something to look out for? Would like to be able to repair them rather than throw them away, they look great (when they work). I searched but it does not look like a common repair item (my luck…)
Loving this site, so far I’ve been able to resurrect an XBOX and a 1st gen Apple TV among other things - hoping to be able to contribute as time goes on.
Here is a picture of the installed light. I haven’t disassembled it yet, but I suspect its similar to any other. Been raining all day, but once it clears I’ll try to get more details.
thanks!
adam
Questa è una buona domanda?
5 Commenti
Do you have any more information on this light fixture? Any pictures of what you are looking at? Could be an issue with the LED or the LED driver but we need to see more
da oldturkey03
@oldturkey03 Hi Oldturkey - I just edited the OP just to give an idea of the style of light we are talking about. If it stops raining for any length of time, i'll get them apart and post more pics. Can you elaborate on the LED driver? Where does one get component-level parts for these things anymore?
wish I saw these reviews before we bought them... https://www.build.com/product/summary/14...
da Adam Yavner
Your LED needs a circuit that will enable it to turn your normal AC voltage in what it needs to start up since there are no 110V/22v (depends on where you live) LED's yet. It is most likely an inverter circuit etc. with multiple LED's. So ....you said it was getting dim first etc. sounds to me like the "LED driver board" will be part of the issue. Most of those boards are repairable if things are properly marked etc. SO, we'll need to see more so that we can help you with your repair. I'd expect to find something like this in your light
da oldturkey03
OK - I bet that will get me on the right track! Assuming its the driver, I'll try to find a replacement/aftermarket one that is of higher quality than what they put in there to begin with. Stay tuned, will post pics etc once I have them apart.
da Adam Yavner
Ok sorry for the delay. double-checked the wiring, and the 120 VAC to the fixtures. Here are a couple of pics - looks like a sealed unit, and it seems like a bit of a burn just to the left of the fuse (F1). I don’t know if I can get it apart enough to test these or if i’d be better off looking for a replacement that will fit.
Pics in the OP -- it wouldn't let me upload into a comment.
Will keep y’all updated..
da Adam Yavner
