Salta al contenuto principale
Repair guides and support for your Samsung TV.
2614 Domande Visualizza tutte
Samsung 40" LED UA40EH5000R - Bootloop issue
Hi Experts,
I have Samsung LED TV UA40EH5000R. Since today morning, it is showing continuous restart issue in every 2 seconds. As a basic user, I googled it and found few basic checks. So, I opened the back panel, cleaned the connection from dust, unplugged and plugged it back. No luck.
But, in that check I found below observation.
  1. When I unplugged the cable from PSU to main board, the TV does not gave any startup sound and it did not show any LED backlight on.
# Then, I unplugged the cable to LED backlight. The TV got started but obviously no image on screen. But, TV did not restart again and it was on without any bootloop issue.
  1. Then with the TV on, I plugged the LED backlight cable into PSU, and to my surprise image was back and TV was running normal again.
  2. But, then I switched TV off , switched it on and it went into same issue. I repeated above two steps few times and TV was back to normal that way until it is switched off.
So, I was curious that is there something wrong with my PSU supplying power to LED backlight or LED itself has any issue. Tested the LED light in dark room and looks ok to me. Then, I checked the PSU carefully and there was one capacitor looks leaked/burnt.
Could this be an issue for this bootloop?
PSU is BN44—00496A.
Thanks in advance
Amit
Questa è una buona domanda?
Punteggio 0
Aggiungi un commento
1 Risposta
Risposta Più Utile
Amit Bhoyar  yes anytime you have a failed component on any board you know there will be issues. At minimum you do want to go ahead and replace the capacitor and clean the trace before replacing it. Check your complete board and see if there are any other parts that look damaged etc. Schematics are not readily available for your power board so you depend on your troubleshooting skills. Ultimately your error seems to originate from the power board regardless of the capacitor.
Punteggio 1
1 Commento:
@oldturkey03 - Thanks for the reply. Yes, I will try to get this done and report back.
da
Aggiungi la tua risposta
Amit Bhoyar sarà eternamente grato.
Visualizza Statistiche:
Ultime 24 Ore: 2
Ultimi 7 Giorni: 6
Ultimi 30 Giorni: 11
Tutti i Tempi: 359
