Salta al contenuto principale
The Nikon Coolpix A900 is a compact user friendly camera, with an adjustable screen that makes it easy for different camera and video angles.
7 Domande Visualizza tutte
please help my camera won’t let me click an answer
hi my camera is stuck on “choose time zone and set date and time” how do i get rid of this. it won’t let me click menu to cancel and it won’t let me choose an option please help
Questa è una buona domanda?
Punteggio 0
1 Commento:
Hi Ashley, have you got any solution for this problem cause I am also facing same issue.
da
Aggiungi un commento
1 Risposta
Hi,
Try a power refresh and check if this resolves the problem.
Turn off the camera and then remove the battery from the camera. (see image)
Press and hold the camera’s Power On/Off button for a full 30 seconds and then release.
Reinsert the battery and try turning on the camera and adjusting the settings.
This may not work as there is a backup power supply (capacitor) on the motherboard that maintains the settings when the battery has been removed. If any data has been corrupted preventing normal operation a power refresh may not restore the data back to default. You can only try.
(click on image to enlarge for better viewing)
Punteggio 0
Aggiungi la tua risposta
ashley smith sarà eternamente grato.
Visualizza Statistiche:
Ultime 24 Ore: 0
Ultimi 7 Giorni: 6
Ultimi 30 Giorni: 17
Tutti i Tempi: 878
