Salta al contenuto principale
Guide per il dispositivo e la riparazione per lo smartphone Huawei P30. Smartphone di punta della Huawei, rilasciato a marzo 2019, con uno schermo OLED da 6,1” e il sensore impronte digitali integrato nello schermo.
Phone isnt connecting to mobile Network
My Huawei p30 is not connecting to any mobile network, Wifi & bluetooth is still working. Resetting the phone did not fix the problem. Are there some suggestiongs, on what i could do to fix it?
Questa è una buona domanda?
Punteggio 1
Aggiungi un commento
1 Risposta
Risposta Più Utile
Hi,
Does the phone detect the SIM card OK?
Try inserting a different compatible, known working, network compatible SIM card in your phone and inserting your SIM card in another same network connected phone to see what works where i.e. basically swap same size SIM cards between your phone and another known working same network connected phone.
Punteggio 3
3 Commenti:
Hey, the SIM card is working fine in other phones, while other cards in the p30 also dont work. I already reset the phone, i didnt fix the issue.
da
@niyetw
By reset do you mean a factory restore?
If so then it is a hardware problem. Faulty SIM card reader perhaps
da
i have trye all above but still nothing coming up
da
Aggiungi la tua risposta
niyetw sarà eternamente grato.
Visualizza Statistiche:
Ultime 24 Ore: 0
Ultimi 7 Giorni: 1
Ultimi 30 Giorni: 7
Tutti i Tempi: 137
