Salta al contenuto principale
change the power supply for ps3 slim from 220v to 110v
hi
I'm abdulaziz
I have a real problem with my ps3 slim
the problem is : my ps3 work in 220v and I in the U.S and U.S only have 110v so my ps3 wont work only if I use a converter . the converter overheat every hour and turn off automatically and after on hour later it work again . I tried to buy another converter but all of them the same (will turn off) I play ps3 more than 6 hour a day and these converter want me get killed by not working ...
can you please tell me if I can buy a 110v power supply and change my 220v power supply and where I can get it plz .. and if I can't can you tell me about a converter that work more than 5 hours or any good converter beside the one I have ?
Questa è una buona domanda?
Punteggio 5
1 Commento
+ For your feedback to help others.
da
Aggiungi un commento
2 Risposte
Risposta Più Utile
abdulaziz,you should not have to use a transformer at all. the power supply in the PS3 Slim have universal power supply to be able to operate 100-240V 50/60Hz. All you may need is a power cord from the power supply to the electrical outlet.
Punteggio 3
13 Commenti:
mine is not 110v
it only handle 220v . I had read the back of PS3
it say that it only will work with 220v
i tried 110v but it didn't work
da
Have you actually taken a look at the inside on your power supply? Just make sure, it is not uncommon to have it labelled on the outside for the origin country. I have not heard of Sony using separate power supplies for different countries, but anything is possible. Anyway, instead of buying a transformer, get a power supply for the 110V they are easily available and not a bad price http://www.thegamersfix.com/product.php?... Are you sure yours won't work on 110???:-)
da
yes I'm Sure ... Thank you bro
can you tell me how i can change the power supply by video or images plz?
da
there is a good guide here Sostituzione alimentatore PlayStation 3 Slim are you sure your power supply is not a dual power supply? I would hate for you to have to change it...;-)
da
what is the "dual power supply" ? can you tell me please ?
how can I know if my ps3 dual ?
do you want me to take a picture of my PS3 slim and up upload it here ?
da
Mostra altri 8 commenti
I just plugged mine in after shipping our stuff from the UK to Canada and it works.
The label says 220-240v and it just works.
Punteggio 0
Aggiungi la tua risposta
abdulaziz sarà eternamente grato.
Visualizza Statistiche:
Ultime 24 Ore: 1
Ultimi 7 Giorni: 9
Ultimi 30 Giorni: 28
Tutti i Tempi: 13,716
