Salta al contenuto principale
Il telefono allora al top della gamma Samsung, il Galaxy S8, è stato lanciato nell'aprile 2017.
304 Domande Visualizza tutte
forget the direction arrows
How do you get back into your phone if you do get the direction arrows
Questa è una buona domanda?
Punteggio 1
2 Commenti
Hi this is Matthew i need alo t of help
da
@kramerm
More information is required to help you.
What is the make and model number of the device?
What is the problem that you're having with the device?
Ask a new question on ifixit rather than posting a question in an answer on another thread.
Here's how to do this https://www.ifixit.com/Answers/Ask
da
Aggiungi un commento
2 Risposte
Risposta Più Utile
If by direction arrows you are referring to the draw-style passcode lock, unfortunately it won’t be easy to access the device. If you’re logged into your Google Account on the device, theres a chance you can remotely unlock the device or change the password. I’m not 100% sure but I believe you may be able to do the same with a Samsung account. If neither of these will work for you and you aren’t capable of hacking the phone to remove it, the only option left would be to reset the phone, losing all data.
Punteggio 1
I need it because it has to be good
Update (12/16/2021)
Please reset my direction Arrows
Punteggio 0
Aggiungi la tua risposta
Jade Comeau sarà eternamente grato.
Visualizza Statistiche:
Ultime 24 Ore: 0
Ultimi 7 Giorni: 0
Ultimi 30 Giorni: 4
Tutti i Tempi: 193
