Salta al contenuto principale
A2115 / 2020 / Processori da 3,1 GHz a 6 core i5, fino a 3,8 GHz a 8 core i7. Lanciato sul mercato il 4 agosto 2020.
44 Domande Visualizza tutte
How thick is the display assembly on the iMac?
Hi, I’ve been doing some thinking about the design of the new M1 iMac and would like to know how thick the display assembly (back of LCD to front of glass) of the 5K iMac is, as it is the closest Apple display that I can think of to the new one.
Questa è una buona domanda?
Punteggio 0
Aggiungi un commento
1 Risposta
Soluzione Prescelta
Apple has managed to shrink the thickness of the display assembly every generation so it wouldn’t surprised me they managed to do it again!
As to thickness of the current 27” 5K display its about 10 mm at its thickest point where the T-CON board is located. Review Step 5 & 6 here: Smontaggio iMac Intel Retina 5K 27"
Given the fact the 24” M1 system is 11.5 mm they clearly thinned it down a bit more. Even still there is nothing really on the backside of the display assembly other than a set of air chambers, WiFi & BT antennas, small I/O board and ribbon cables to get around all of which are thin. Here’s an educated guess on what’s inside!
Punteggio 1
2 Commenti:
Thanks a lot, that's a great resource and points me in the right direction and seems to make a lot of sense when it comes to the existence of the chin.
da
@coffeee - Yup they needed the chin! Even still the power supply is now external which is the largest part one would find in the current Intel iMac systems.
da
Aggiungi la tua risposta
coffee sarà eternamente grato.
Visualizza Statistiche:
Ultime 24 Ore: 2
Ultimi 7 Giorni: 7
Ultimi 30 Giorni: 8
Tutti i Tempi: 135
