Salta al contenuto principale
In seguito alla forma più sottile e più piccola del Lenovo Yoga due in uno, il Lenovo IdeaPad Flex 5-1570 ti offre un'ottima performance, usando un processore Intel Core i5-8250U da 1.6GHz e un adattatore video integrato Intel UHD Graphics 620.
Can the Lenovo IdeaPad Flex 5-1570 Keyboard be Replaced?
My Lenovo IdeaPad Flex 5-1570 80XB keyboard has a few keys that no longer respond. I bought a compatible replacement part on Amazon. It arrived with about 20 holes in it. I thought the holes aligned with something for it to snap into place. Searching further online yields very little about replacing this model’s keyboard. One site says the keyboard is riveted into the palm rest and is not removable. Can this model’s keyboard truly be replaced? If so, how? Thanks!
Questa è una buona domanda?
Punteggio 1
Aggiungi un commento
1 Risposta
Risposta Più Utile
Hi @ncdad ,
The keyboard is part of the upper case assembly and it has to be cut out of the assembly if you want to replace it.
Not sure with your exact model but with others it is held in with plastic rivets that can be melted or cut away so that the keyboard can be removed and then you have to glue the new one back in somehow.
It wasn’t really designed to be an easily replaceable component, separate from the upper case.
Here’s the hardware maintenance manual for the laptop. Go to p.49 to view the necessary pre-requisite steps and then the procedure to remove the upper case assembly.
Punteggio 2
Aggiungi la tua risposta
NCDad sarà eternamente grato.
Visualizza Statistiche:
Ultime 24 Ore: 0
Ultimi 7 Giorni: 4
Ultimi 30 Giorni: 23
Tutti i Tempi: 3,885
