Salta al contenuto principale
S.M.A.R.T status "PROBLEM check"
Hi, I recently bought a 512GB WD SN530 2242 SSD on eBay, but unfortunately the S.M.A.R.T status is not working.
I recently did a diagnostic, here are the results:
  1. SYSTEM INFORMATION ###
Report Timestamp : 12 aprile 2021 11:05:11 CEST
Report Timestamp (ISO 8601 format) : 2021-04-12T11:05:11
Application Name : DriveDx
Application Version : 1.10.1.701
Application SubBuild : 0
Application Edition : Standalone
Application Website : https://binaryfruit.com/drivedx
DriveDx Knowledge Base Revision : 100/100
Computer Name : MacBook Pro di Claudio
Host Name : MacBook-Pro-di-Claudio
Computer Model : MacBookPro14,1
OS Boot Time : 2021-04-11T12:10:09
Time Since Boot : 22h 55m 02s
OS Name : macOS
OS Version : 10.16.0
OS Build : 20D91
OS Kernel Version : Darwin 20.3.0
SAT SMART Driver Version : N/A
ATA Command Support Tolerance : verypermissive
N of drives with S.M.A.R.T support : 1
  1. DRIVE 1 OF 1 ###
Last Checked : 12 aprile 2021 11:04:49 CEST
Last Checked (ISO 8601 format) : 2021-04-12T11:04:49
Advanced SMART Status : FAILED
Overall Health Rating : N/A 100%
SSD Lifetime Left Indicator : GOOD 100%
Issues found : 3
Serial Number : 2030BD808716
WWN Id :
Volumes : Macintosh HD
Device Path : /dev/disk0
Total Capacity : 512.1 GB (512.110.190.592 Bytes)
Model Family : Western Digital NVMe SSD
Model : WDC PC SN530 SDBPMPZ-512G-1101
Firmware Version : 21110001
Drive Type : SSD
Power On Time : 27 hours (1 days 3 hours)
Power Cycles Count : 7
Current Power Cycle Time : 22.9 hours
DEVICE CAPABILITIES
S.M.A.R.T. support enabled : yes
DriveDx Active Diagnostic Config : Western Digital NVMe SSD config [ssd.nvme.wd.def.01]
Sector Logical Size : 512
Sector Physical Size : 512
Physical Interconnect : PCI-Express (PCIe)
Logical Protocol : NVM-Express (NVMe)
Removable : no
Ejectable : no
NVMe Revision Supported : 1.40
PCI Vendor Id : 0x15b7
Thermal Throttling Supported : no
Volatile Write Cache Supported : yes
Maximum Data Transfer Size : 128 Pages
Log Page Attributes : 0x1e
Format NVM Attributes : 0x0
Optional Admin Command Support : 0x0
Optional NVM Command Support : 0x5f (Compare, Wr_Unc, DS_Mngmt, Wr_Zero, Save/Sel_Feat, +)
Number of Power States Supported : 4
Error Log Page Entries : 255
Keep Alive Support : 0
Total NVMe Capacity : 512.110.190.592 (512.1 GB)
Unallocated NVMe Capacity : -
Number of NVMe Namespaces : 1
I/O Path : IOService:/AppleACPIPlatformExpert/PCI0@0/AppleACPIPCI/RP01@1C/IOPP/SSD0@0/IONVMeController/IONVMeBlockStorageDevice@1
[Known device ]: yes
[Drive State Flags ]: 0x2000202
[Last State Change Timestamp ]: 2021-04-12T10:59:07
[Last State Change Flags ]: 0x2000202
[Last State Change Diff Flags ]: 0x1
Last Email Report Timestamp : 2021-04-12T10:59:07
Last Email Report Reason Flags : 0x2000202
Last Email Report State Change Flags : 0x1
CURRENT POWER CYCLE STATISTICS
Data Read : 4.0 GB
Data Written : 2.9 GB
Data Read/Write Ratio : 1.40
Average Throughput (Read) : 78.6 MB/s
Average Throughput (Write) : 152.7 MB/s
Operations (Read) : 265.306
Operations (Write) : 132.982
Operations Read/Write Ratio : 2
Throughput per operation (Read) : 15.9 KB/Op
Throughput per operation (Write) : 22.7 KB/Op
Latency Time (Read) : 0 ns
Latency Time (Write) : 0 ns
Retries (Read) : 0
Retries (Write) : 0
Errors (Read) : 15
Errors (Write) : 0
PROBLEMS SUMMARY
Failed Indicators (life-span / pre-fail) : 0 (0 / 0)
Failing Indicators (life-span / pre-fail) : 1 (0 / 1)
Warnings (life-span / pre-fail) : 0 (0 / 0)
I/O Error Count : 15 (15 / 0)
IMPORTANT HEALTH INDICATORS
ID NAME RAW VALUE STATUS
7 Data Units Written 609.531 (290.6 GB) 100% OK
14 Media and Data Integrity Errors 332 100% Failing
TEMPERATURE INFORMATION (CELSIUS)
Current Temperature : 30
Power Cycle Min Temperature : 30
Power Cycle Max Temperature : 30
Lifetime Min Temperature : 30
Lifetime Max Temperature : 30
Recommended Min Temperature : 5
Recommended Max Temperature : 80
Temperature Min Limit : 5
Temperature Max Limit : 85
DRIVE HEALTH INDICATORS
ID | NAME | TYPE | UPDATE | RAW VALUE | VALUE | THRESHOLD | WORST | LAST MODIFIED | STATUS
2 Composite Temperature Life-span online 30 (30 °C) 70 15 70 - 64.7% OK
3 Available Spare Pre-fail online 100 100 10 100 - 100% OK
5 Life Percentage Used Life-span online 0 100 0 100 - 100% OK
6 Data Units Read Life-span online 661.332 (315.3 GB) 100 0 100 - 100% OK
7 Data Units Written Life-span online 609.531 (290.6 GB) 100 0 100 - 100% OK
8 Host Read Commands Life-span online 9.683.796 100 0 100 - 100% OK
9 Host Write Commands Life-span online 8.624.320 100 0 100 - 100% OK
10 Controller Busy Time Life-span online 14 (14 minutes) 100 0 100 - 100% OK
11 Power Cycles Life-span online 7 100 0 100 - 100% OK
12 Power On Hours Life-span online 27 (27 hours) 100 0 100 - 100% OK
13 Unsafe Shutdowns Life-span online 0 100 0 100 - 100% OK
14 Media and Data Integrity Errors Pre-fail online 332 100 0 100 - 100% Failing
15 Error Information Log Entries Pre-fail online 0 100 0 100 - 100% OK
16 Warning Composite Temperature Time Life-span online 0 (0 minutes) 100 0 100 - 100% OK
17 Critical Composite Temperature Time Life-span online 0 (0 minutes) 100 0 100 - 100% OK
DRIVE ERROR LOG
error log is empty
Is there anything I can do? Or do I proceed with the return of the SSD to eBay?
Questa è una buona domanda?
Punteggio 0
Aggiungi un commento
1 Risposta
Risposta Più Utile
Sadly you are hitting the limits of an M.2 drive being used in a MacBook Pro system which was not designed for the M.2 SSD’s with these adapters.
I often pull them out of systems as they just don’t hold up. Sure you use them for a time and they look so good! If you are a heavy user you’ll kill it in no time.
Best to stick with either an Apple SSD or one of the 3rd party drives which are properly designed for your system OWC or Transcend.
Here’s a bit more on the Apple SSD’s The Ultimate Guide to Apple’s Proprietary SSDs
So return it get your money back and invest it in a better drive.
Punteggio 1
Aggiungi la tua risposta
Claus12 sarà eternamente grato.
Visualizza Statistiche:
Ultime 24 Ore: 0
Ultimi 7 Giorni: 1
Ultimi 30 Giorni: 9
Tutti i Tempi: 835
