S.M.A.R.T status "PROBLEM check"
Hi, I recently bought a 512GB WD SN530 2242 SSD on eBay, but unfortunately the S.M.A.R.T status is not working.
I recently did a diagnostic, here are the results:
- SYSTEM INFORMATION ###
Report Timestamp : 12 aprile 2021 11:05:11 CEST
Report Timestamp (ISO 8601 format) : 2021-04-12T11:05:11
Application Name : DriveDx
Application Version : 1.10.1.701
Application SubBuild : 0
Application Edition : Standalone
Application Website : https://binaryfruit.com/drivedx
DriveDx Knowledge Base Revision : 100/100
Computer Name : MacBook Pro di Claudio
Host Name : MacBook-Pro-di-Claudio
Computer Model : MacBookPro14,1
OS Boot Time : 2021-04-11T12:10:09
Time Since Boot : 22h 55m 02s
OS Name : macOS
OS Version : 10.16.0
OS Build : 20D91
OS Kernel Version : Darwin 20.3.0
SAT SMART Driver Version : N/A
ATA Command Support Tolerance : verypermissive
N of drives with S.M.A.R.T support : 1
- DRIVE 1 OF 1 ###
Last Checked : 12 aprile 2021 11:04:49 CEST
Last Checked (ISO 8601 format) : 2021-04-12T11:04:49
Advanced SMART Status : FAILED
Overall Health Rating : N/A 100%
SSD Lifetime Left Indicator : GOOD 100%
Issues found : 3
Serial Number : 2030BD808716
WWN Id :
Volumes : Macintosh HD
Device Path : /dev/disk0
Total Capacity : 512.1 GB (512.110.190.592 Bytes)
Model Family : Western Digital NVMe SSD
Model : WDC PC SN530 SDBPMPZ-512G-1101
Firmware Version : 21110001
Drive Type : SSD
Power On Time : 27 hours (1 days 3 hours)
Power Cycles Count : 7
Current Power Cycle Time : 22.9 hours
DEVICE CAPABILITIES
S.M.A.R.T. support enabled : yes
DriveDx Active Diagnostic Config : Western Digital NVMe SSD config [ssd.nvme.wd.def.01]
Sector Logical Size : 512
Sector Physical Size : 512
Physical Interconnect : PCI-Express (PCIe)
Logical Protocol : NVM-Express (NVMe)
Removable : no
Ejectable : no
NVMe Revision Supported : 1.40
PCI Vendor Id : 0x15b7
Thermal Throttling Supported : no
Volatile Write Cache Supported : yes
Maximum Data Transfer Size : 128 Pages
Log Page Attributes : 0x1e
Format NVM Attributes : 0x0
Optional Admin Command Support : 0x0
Optional NVM Command Support : 0x5f (Compare, Wr_Unc, DS_Mngmt, Wr_Zero, Save/Sel_Feat, +)
Number of Power States Supported : 4
Error Log Page Entries : 255
Keep Alive Support : 0
Total NVMe Capacity : 512.110.190.592 (512.1 GB)
Unallocated NVMe Capacity : -
Number of NVMe Namespaces : 1
I/O Path : IOService:/AppleACPIPlatformExpert/PCI0@0/AppleACPIPCI/RP01@1C/IOPP/SSD0@0/IONVMeController/IONVMeBlockStorageDevice@1
[Known device ]: yes
[Drive State Flags ]: 0x2000202
[Last State Change Timestamp ]: 2021-04-12T10:59:07
[Last State Change Flags ]: 0x2000202
[Last State Change Diff Flags ]: 0x1
Last Email Report Timestamp : 2021-04-12T10:59:07
Last Email Report Reason Flags : 0x2000202
Last Email Report State Change Flags : 0x1
CURRENT POWER CYCLE STATISTICS
Data Read : 4.0 GB
Data Written : 2.9 GB
Data Read/Write Ratio : 1.40
Average Throughput (Read) : 78.6 MB/s
Average Throughput (Write) : 152.7 MB/s
Operations (Read) : 265.306
Operations (Write) : 132.982
Operations Read/Write Ratio : 2
Throughput per operation (Read) : 15.9 KB/Op
Throughput per operation (Write) : 22.7 KB/Op
Latency Time (Read) : 0 ns
Latency Time (Write) : 0 ns
Retries (Read) : 0
Retries (Write) : 0
Errors (Read) : 15
Errors (Write) : 0
PROBLEMS SUMMARY
Failed Indicators (life-span / pre-fail) : 0 (0 / 0)
Failing Indicators (life-span / pre-fail) : 1 (0 / 1)
Warnings (life-span / pre-fail) : 0 (0 / 0)
I/O Error Count : 15 (15 / 0)
IMPORTANT HEALTH INDICATORS
ID NAME RAW VALUE STATUS
7 Data Units Written 609.531 (290.6 GB) 100% OK
14 Media and Data Integrity Errors 332 100% Failing
TEMPERATURE INFORMATION (CELSIUS)
Current Temperature : 30
Power Cycle Min Temperature : 30
Power Cycle Max Temperature : 30
Lifetime Min Temperature : 30
Lifetime Max Temperature : 30
Recommended Min Temperature : 5
Recommended Max Temperature : 80
Temperature Min Limit : 5
Temperature Max Limit : 85
DRIVE HEALTH INDICATORS
ID | NAME | TYPE | UPDATE | RAW VALUE | VALUE | THRESHOLD | WORST | LAST MODIFIED | STATUS
2 Composite Temperature Life-span online 30 (30 °C) 70 15 70 - 64.7% OK
3 Available Spare Pre-fail online 100 100 10 100 - 100% OK
5 Life Percentage Used Life-span online 0 100 0 100 - 100% OK
6 Data Units Read Life-span online 661.332 (315.3 GB) 100 0 100 - 100% OK
7 Data Units Written Life-span online 609.531 (290.6 GB) 100 0 100 - 100% OK
8 Host Read Commands Life-span online 9.683.796 100 0 100 - 100% OK
9 Host Write Commands Life-span online 8.624.320 100 0 100 - 100% OK
10 Controller Busy Time Life-span online 14 (14 minutes) 100 0 100 - 100% OK
11 Power Cycles Life-span online 7 100 0 100 - 100% OK
12 Power On Hours Life-span online 27 (27 hours) 100 0 100 - 100% OK
13 Unsafe Shutdowns Life-span online 0 100 0 100 - 100% OK
14 Media and Data Integrity Errors Pre-fail online 332 100 0 100 - 100% Failing
15 Error Information Log Entries Pre-fail online 0 100 0 100 - 100% OK
16 Warning Composite Temperature Time Life-span online 0 (0 minutes) 100 0 100 - 100% OK
17 Critical Composite Temperature Time Life-span online 0 (0 minutes) 100 0 100 - 100% OK
DRIVE ERROR LOG
error log is empty
Is there anything I can do? Or do I proceed with the return of the SSD to eBay?
Questa è una buona domanda?
