Salta al contenuto principale
The Lenovo ThinkPad Yoga 260 is a lightweight, 2 in 1 laptop released in 2016. It can be identified by the model number 8260NGW on the bottom of the device. It is part of Lenovo’s Yoga line and features 4 different usage modes. The Lenovo ThinkPad Yoga 260 features an HD touchscreen that can be rotated 360 degrees.
3 Domande Visualizza tutte
How to get into advanced repair from hard reboot?
I've tried to turn my laptop off and turn it on and then turn it off again right after the manufacturer's logo shows up, and then turn it on, for 3 times more but I can't get into the advanced repair mode.
I can't get into the advanced repair mode from settings or from the sign-in screen, because I can't even get into the sign-in screen.
Did I do it the wrong way or this method doesn't available on my laptop?
My laptop is Lenovo Thinkpad Yoga 260, Windows 10.
Questa è una buona domanda?
Punteggio 0
Aggiungi un commento
1 Risposta
Soluzione Prescelta
Hi @criminalpartn ,
Did you let it start to boot into Windows before shutting it down i.e. Windows startup logo on screen?
It needs to boot as it is Windows that starts the repair startup not the BIOS. BIOS gets it ready to boot i.e. manufacturer’s logo on screen until Windows logo when it is booting into the OS
If still no good create a Win 10 recovery USB from any known working Win 10 PC.
In the host PC go to Control panel > Recovery > create a recovery disc and follow the prompts.
You will need an 8GB flashdrive and 40-60 minutes of time.
When you have the USB, insert the USB in the laptop and start the laptop and get into BIOS and then enable Legacy USB (or CSM), save the changes, then restart the laptop.
It should boot into the Windows Recovery menus off the USB. Go to Troubleshooting > Advanced and select the option you want.
Punteggio 1
Aggiungi la tua risposta
Esther Moeniqa sarà eternamente grato.
Visualizza Statistiche:
Ultime 24 Ore: 1
Ultimi 7 Giorni: 1
Ultimi 30 Giorni: 6
Tutti i Tempi: 1,205
