Salta al contenuto principale
In seguito alla forma più sottile e più piccola del Lenovo Yoga due in uno, il Lenovo IdeaPad Flex 5-1570 ti offre un'ottima performance, usando un processore Intel Core i5-8250U da 1.6GHz e un adattatore video integrato Intel UHD Graphics 620.
10 Domande Visualizza tutte
My laptop bottom base cover is cracked and needs replacemtn
Where can I get a replacement bottom base cover for my Lenovo Flex 4 Series 2-in-1 Touchscreen Laptop . It’s cracked in multiple places and also disconnecting from the hinges. Is there a supplier that can provide replacement parts?
Thanks
Sridhar
Questa è una buona domanda?
Punteggio 0
3 Commenti
The laptop is 15.6".
da
@srig
What is the full model number of the laptop as shown on the information label on the bottom of the laptop?
da
@jayeff
The model number at the bottom reads:
Ideapad Flex 4 - 1580
80-VE
Thanks
Sri
da
Aggiungi un commento
1 Risposta
Soluzione Prescelta
Hi @srig ,
The parts list for your model shows that the part number for the base enclosure (bottom cover) is 5CB0L46025 (Click on Select Commodity > Covers (1) to view the part number).
If you search online using the part number only (example only) in the search term of your browser you will get results for suppliers of the part.
To replace the base enclosure you have to nearly completely dis-assemble the laptop. Here’s the hardware maintenance manual that shows how to remove all the necessary parts to do this, which should help.
Punteggio 1
1 Commento:
@jayeff
Thank you for the links. I used the part number and found the base cover at
https://www.impactcomputers.com/5cb0l460...
Appreciate the assistance.
Thanks
Sri
da
Aggiungi la tua risposta
Sri sarà eternamente grato.
Visualizza Statistiche:
Ultime 24 Ore: 1
Ultimi 7 Giorni: 8
Ultimi 30 Giorni: 24
Tutti i Tempi: 462
