Salta al contenuto principale
L'aggiornamento di Marzo 2015 della linea 13" dei Macbook Pro con Retina Display (modello A1502) adotta processori Intel Core i5 ed i7 di quinta generazione, introduce inoltre il trackpad Force Touch.
1185 Domande Visualizza tutte
MacBook backlight slightly flickering
I closed the lid on my MacBook and after I woke if from sleep the backlight slightly flickers, its a consistent flicker and very slight but also very noticeable. It only happens when there are light colors on the screen (which makes sense if its a backlight issue). When i plugged it in the flicker went away for a few seconds but then it came back. I have already tried resetting smc and pvram/nvram to no avail
Questa è una buona domanda?
Punteggio 0
1 Commento:
Given the ago your system let's first check the battery, install this gem of an app! CoconutBattery take a snapshot of the apps main window and post it here for us to see Aggiungere immagini ad una domanda
da
Aggiungi un commento
1 Risposta
You might want to replace the blacklight pad
Punteggio 0
3 Commenti:
Take a look at this MacBook Pro Retina Display Teardown Jump down to Step 13 where you can see the discreet LED's.
These displays are not really serviceable.
da
Is this about the keyboard or the display, because I thought you were talking about the keyboard
da
@jellybean2_0 - "It only happens when there are light colors on the screen" I think clarifies its the display thats in question.
I wanted to check the battery as a failing battery can cause voltage stability issues. Which in turn would affect the backlight.
da
Aggiungi la tua risposta
Shaan Patel sarà eternamente grato.
Visualizza Statistiche:
Ultime 24 Ore: 0
Ultimi 7 Giorni: 4
Ultimi 30 Giorni: 10
Tutti i Tempi: 118
