Salta al contenuto principale
The smaller of Apple's MacBook Air laptops featuring dual microphones and 802.11ac Wi-Fi connectivity.
149 Domande Visualizza tutte
How can I tighten loose screen on MacBook Air Mid 2013 11-inch
I have seen a video on how to tighten the screws on Macbook Air 11-inch 2013, however, exactly which screwdriver do I need. I already have a wiha P4, which removes the screws on the back of the Macbook. The video says use a T8 screwdriver on the hinge screws. Wiha and other vendors sell a T8 40mm and T8 60 mm. I don’t know which to buy. Don’t know what 40 mm pertains to. Anyone?
Questa è una buona domanda?
Punteggio 1
Aggiungi un commento
1 Risposta
The guide MacBook Air 11" Mid 2013 Display Assembly Replacement lists out the tools you’ll need, jump down to Step 31 for the needed screws that likely need tightening. If the lid is still loose you’ll need to tighten the lid side screws which will require taking the display assembly off to gain access to them.
Punteggio 0
Aggiungi la tua risposta
Jean Cole sarà eternamente grato.
Visualizza Statistiche:
Ultime 24 Ore: 1
Ultimi 7 Giorni: 1
Ultimi 30 Giorni: 2
Tutti i Tempi: 161
