Salta al contenuto principale
Informazioni sul dispositivo e sulla riparazione per i portatili Dell XPS 13 modelli 9343 e 9350, entrambi rilasciati nel 2015.
Replacement battery not recognized, not OEM specs
On battery install, warning about not recognizing battery. I turned off notification in BIOS. It registered 60%, I drained for calibration, now won't work without adapter plugged in and reads battery as 0%. Shuts down when adapter unplugged.
Questa è una buona domanda?
Punteggio 1
2 Commenti:
where did you get the battery from? I wonder if Dell serialized the battery, essentially tying it to that specific machine...
da
I got mine from I fix it and same problem. Warning message on startup that it is not a Dell battery and it refuses to charge it ?
da
Aggiungi un commento
1 Risposta
Dell has stopped supplying these batteries, and my bios tells me the battery is not recognized. I purchased from IFIXIT
Punteggio 0
Aggiungi la tua risposta
Reggie Stecher sarà eternamente grato.
Visualizza statistiche:
Ultime 24 ore: 1
Ultimi 7 giorni: 4
Ultimi 30 giorni: 17
Tutti i Tempi: 568
