Salta al contenuto principale
Rilasciato a Gennaio 2015, l'XPS 13 ambisce ad essere il rivale commerciale del MacBookAir, con lo schermo senza bordi e il Touch-screen opzionale.
75 Domande Visualizza tutte
Replacement battery not recognized, not OEM specs
On battery install, warning about not recognizing battery. I turned off notification in BIOS. It registered 60%, I drained for calibration, now won't work without adapter plugged in and reads battery as 0%. Shuts down when adapter unplugged.
Questa è una buona domanda?
Punteggio 1
2 Commenti:
where did you get the battery from? I wonder if Dell serialized the battery, essentially tying it to that specific machine...
da
I got mine from I fix it and same problem. Warning message on startup that it is not a Dell battery and it refuses to charge it ?
da
Aggiungi un commento
1 Risposta
Dell has stopped supplying these batteries, and my bios tells me the battery is not recognized. I purchased from IFIXIT
Punteggio 0
Aggiungi la tua risposta
Reggie Stecher sarà eternamente grato.
Visualizza Statistiche:
Ultime 24 Ore: 0
Ultimi 7 Giorni: 1
Ultimi 30 Giorni: 4
Tutti i Tempi: 207
