Salta al contenuto principale
Numero modello A1707. Rilasciato a giugno 2017, questo MacBook Pro adotta processori Kaby Lake fino a Intel Core i7 quad core da 2,8 GHz con Turbo boost fino a 3,8 GHz.
broken locking flap for the battery board data cable
Broken the locking flap on the zif connector for the battery board data cable when I tried to change the screen, is there any way to fix it?
It’s a MacBook Pro 15 inch 2017
Questa è una buona domanda?
Punteggio 3
3 Commenti
Do you still have the latch? Post a few pics of it so we can see if its still good Aggiungere immagini ad una domanda
da
Thanks for your reply! Unfortunately the latch is broken into two pieces is will it not work without the latch? I tried putting the cable in place and holding it in place with tape. But the computer does not find the battery.
da
Hi, I have the same issue, the 'latch' juste came butv is still in one piece. How am I supposed to re-attach or re-insert it properly?
da
Aggiungi un commento
4 Risposte
Soluzione Prescelta
@gabriel111 - You need the compression of the latch.
Sadly, I haven’t found a source for this connector. Your only hope is finding someone who fixes Mac’s who has a junker to take the latch from.
Punteggio 1
2 Commenti:
I have a water damaged MacBook Pro that I can take the latch from but I don’t know how to connect back the latch, because it first fell out when I tried to close it, and was broken into two parts when I tried to put it back in place, it’s very small
da
@gabriel111 - If you look carefully at the latch and the body of the connector you can see how it snaps in.
If you can't tell I think you'll need to find someone local who has a bit more skill to help you.
da
Risposta Più Utile
I have a solution that worked for me – should work for you too!
I accidentally broke my retaining flap as well on the battery board data cable connector.
What fixed it: I used the black pull tab on the battery cable and removed it and put it underneath the end of the cable that was missing the retaining flap. I didn’t put the adhesive side “head-first” into the socket, i put the side without adhesive “head-first” and used the adhesive to connect it to the underside of the cable. Then I slid the cable end + pull flap underneath into the socket and used a piece of tape over the cable and connector and over where the flap would have been, and secured the other end of tape onto the logic board – it seems to have enough pressure from underneath to do the trick!
My 2017 MacBook Pro 13” Touchbar (A1706) now sees the battery and is running on battery power alone!
Sorry if my explanation wasn’t very clear – let me know if you have questions!
Punteggio 5
5 Commenti:
I saw on your photo to you don't have the black pull tab on the cable. You should be able to carefully cut a thin strip of electrical tape (maybe not because we don't want the adhesive stuck in the socket) OR you can try a thin piece of plastic from a retail package. Make sure it's about as wide as the cable. use electrical or Kapton tape to connect the strip to the cable on the underside. Follow the rest of my recommendation by securing it all once in place with another piece of Kapton tape or other tape.
da
Hey, I had this same issue. I followed your instructions — I think another way of putting it is that you’re building up the battery cable thickness so the connections are pressed more firmly into the locking tab from below — and it worked!
Thank you! I’ve missed my little A1706 pal.
da
Thank you for your solution, this trick worked for me as well! I cut off the pull tab from the old battery cable and pushed it into the socket then forced the battery cable in on top of it then used some electrical tape to hold it in place.
da
Hey! I recently had the same issue when replacing my screen. I accidentally broke the latch and I found your comment. I have been trying for 5 hours to fix it and I dont think im doing it right. Do you have any photos that could help me. I tried to do something nice for my gf and fix her screen now the battery isnt working :(
da
Steve, I owe you one. I shall erect a pyramid in your honor.
I was repairing a 2017 MBP and managed to snap off the latch from the power connector on the mobo. Thought I was going to have to try to salvage one from a broken mobo or (worse) replace the whole mobo.
Using the "cut off the pull tab and reuse it" method gave me intermittent results... but using a cut-to-sized piece of black electrical tape worked perfectly. After adhering it to the bottom of the cable, I jimmied the cable into the socket using tweezers and a rocking motion, pressing until I knew it was in as far as it would go.
Once I ensured that the system powered on properly from the battery, I secured the cable to the motherboard using pieces of packing tape.
Seriously man... GREAT stuff. I am sure I will reuse this technique often as needed.
da
I had this exact same problem. After having to replace the screen on my 2020 MacBook Pro 13" having thrown coffee over it, it wouldn't power on. However, I researched and found this article.
It turned out that ribbon cable had broken, presumably internally, and when I flipped the compression latch up on the larger of the two ends, it somehow let go and launched itself into orbit never to be seen again!
I ordered a new cable from Germany along with some Kapton tape. I shimmed the end of the ribbon cable with two pieces of Kapton tape and using tweezers, persuaded the cable into the connector (okay, I admit the wrong way up first time, second time lucky!) At this point I turned the laptop over and powered on.....nothing. I did wonder if the battery had run flat, unlikely but not impossible, so I connected the power cable and of course it powered up. The difference this time was a battery icon on the display whereas before there was no icon and the display was multicoloured flashes and full speed fans etc. The battery was now showing 100% so I guess it needed a 'jump start' using mains power.
It's now happily reloading Monterey and I'm hoping all is resolved.
Thank you for the above, it inspired me to have another go at repairing the old girl, though what I will do with it I'm not sure as I replaced it with a new 14" MacBook Pro. Maybe some lucky soul on eBay.......
Punteggio 0
BMU SINGLE FLEX CABLE, Macpro Mid 2016 / 2017. The connector where it goes looks different. The securement piece is broken at the two ends. How can I fix this? A technician most likely did this and didn't tell me, as the cover is missing. Relying on the fact, I will never open it. But here I am. Please advice.
Punteggio 0
1 Commento:
I went straight for the electrical tape option. Started up the computer and instead of the triangle I had a time to charge! I spoke with a local computer fixit guy and he could replace the price for $300! He warned me that the electrical tape solution won’t last… let’s see how long it will last. I’m willing to try this solution vs the $300
da
Aggiungi la tua risposta
Gabriel sarà eternamente grato.
Visualizza Statistiche:
Ultime 24 Ore: 3
Ultimi 7 Giorni: 26
Ultimi 30 Giorni: 94
Tutti i Tempi: 4,529
