Salta al contenuto principale
A1708 / EMC 2978 — Lanciato nell'ottobre 2016, questo MacBook Pro entry-level conserva i tradizionali tasti funzione (invece della Touch Bar OLED). La versione function key adotta l'Intel Core i5 e 2 porte Thunderbolt.
216 Domande Visualizza tutte
MacBook Pro 13 2016 light bleed
Just want to share my CRAZY story regarding those 2016 models.
I got it nearly NEW - yes - 2016 but NEW - DriveDX app reports SSD been powered just 72 hours - YES - just 72 hours and MacBook developed “light bleed”
My point is…… it is NOT happening because opening lid more than 40 degree (which I never even done!) It is just……… “TICKING BOMB” - it is just dying because…… it HAS TO die.
Update (02/19/2021)
Here is what I see
Questa è una buona domanda?
Punteggio 0
5 Commenti
Please post a picture so we can see what you are seeing Aggiungere immagini ad una domanda
There are a few extended warranties on this system which I would take advantage of. But your time is short!
As an example 13-inch MacBook Pro Display Backlight Service Program
da
I had chat with Apple and they saw it - yes - I will get new screen - and CORRECT - I got time till........ Fall this year.
My point was - MacBook is virtually NEW (used 72 hours) - and display still DIES (I meant - has light bleed)
da
It would have been helpful to have seen the picture.
da
[image|2333138]
Here is what I see.
And I would go to Apple Shop - but……. all of them in UK they are SHOUT……… because Lockdown 2
da
@Bart - Yes, COVID sucks!
At this point there is nothing more we can offer you. Don't forget to score the answer and accept it - Thanks!
da
Aggiungi un commento
1 Risposta
Soluzione Prescelta
Any ways…. Apple has you covered!
At least you got a freebee! If you hadn’t posted here would you have known of the extended warranty? It would have cost you a bit of coin needlessly!
Update (02/19/2021)
Here’s your issue, it’s called FlexGate! The Design Flaw Behind MacBook Pro’s “Stage Light” Effect and 2018 MacBook Pros Try to Solve Flexgate Without Admitting It Exists
Punteggio 1
1 Commento:
I've updated main question with photo - thank You Dan
da
Aggiungi la tua risposta
Bart sarà eternamente grato.
Visualizza Statistiche:
Ultime 24 Ore: 2
Ultimi 7 Giorni: 4
Ultimi 30 Giorni: 6
Tutti i Tempi: 156
