Salta al contenuto principale
Released in the Summer of 2011, identified by "XPS L401X" on the bottom of the laptop. Model Number: 14 L401X.
I want to change the HDD into SSD
I want to change the existing HDD into SSD. I have cloned it but when I put SSD into HDD slot, it is not bootable and cannot be read by the BIOS. My SSD is Samsung EVO 850 1TB. Is there any limitation of the motherboard?
Questa è una buona domanda?
Punteggio 0
Aggiungi un commento
1 Risposta
Hi,
According to this supplier they guarantee that their 2TB SSDs will work so it appears that there is no limitation on the motherboard.
As the SSD is not being detected in BIOS, did your SSD come with a 7mm to 9.5mm adapter? (supplier example only)
The adapter is designed to hold a 7mm SSD (which yours is) in the correct position in a 9.5mm drive bay (which your laptop has) so that there is good contact between the SSD and the sata connector in the laptop
Punteggio 0
1 Commento:
Hi jayeff,
Thanks for responding my question. So basically I need to buy SSD spacer from 7mm SSD to 9.5mm. I will look into it first and come back to you ASAP.
da
Aggiungi la tua risposta
Yusfa Anugrah Baihaki sarà eternamente grato.
Visualizza Statistiche:
Ultime 24 Ore: 0
Ultimi 7 Giorni: 2
Ultimi 30 Giorni: 6
Tutti i Tempi: 234
